Toyota Premium Horns installed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rcsting, Jul 18, 2009.
  1. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    yes, the 12mm racheting wrench worked excellent for this task. you should add a set to your arsenal of tools.
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Thanks to you both!
  3. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Any help on what bolts need to be removed would be very much appreciated.
    Thanks.
  4. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I think I'll wait until I can get a horn that plays, Its Not Easy Being Green. :)
  5. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    My Harley had a wimpy horn. Solved it with an add on. Got one from a company called Wolo, model name BadBoy. Very compact airhorn with a small trumpet and compressor in a 5x4x3 inch package. Simple install was with a standard relay using the power wire to the factory horn as the power to the coil side of the relay. I found the horn at PepBoys for under $50, then got to kick myself when I spotted it at Harbor Freight for $35.
  6. Bear68
    Bear68 Member
    373
    72
    OH Yeah..... it is surprisingly LOUD!!! Especially on a Harley....
