Ummm....I am getting 26-27 MPG......
Discussion in 'Gen 2 Prius Fuel Economy' started by QuelleFromage, Jun 15, 2008.
  1. QuelleFromage
    QuelleFromage New Member
    I was a little concerned in my first week of Prius ownership as I was getting about 34-35 MPG. I read up everything in this forum and figured that maybe my driving style was putting a dent in the mileage, although I do coast and glide and so forth. My commute is also a LOT of stop-and-go. So, I was getting a bit bummed but figured I'd work on it. Now I'm down to 26-27 average :eek: and I am completely confused.
    This weekend I have been doing more highway driving and much less stop-and-go in the city. It HAS been hot out and I've had the AC on low - does the AC make that much difference?
    I rented a Prius about three or four years ago and had it for two or three weeks. I got GREAT mileage and I never stopped for gas once- returned the car pretty much full. So it can't all be me and my driving.
    I have put a whopping 50 miles on this car and the gas tank is down two pips. Freaking me out. :(
    I am not looking to get 60 MPG, or even EPA mileage necessarily. But it'd be nice to get up into the 40's. Help!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    What have you done to troubleshoot? tire pressure, oil level? Emergency brake?
    What's your usual commute?
    Have you gone out on a rural road where you can drive a steady 35 or 40mph for an extended time (20-30 miles) and seen what your MPG shows there?
    If you're getting in the 20s something is not right.
  3. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Quelle...,
    How you run the AC can make a big difference. In stop and go, there is just not any extra engine operation to charge the battery, so the overhead of starting and running the engine is used only for climate control. That said, if you run Max Cool the engine will run allot. The beuty of the Prius climate control is the variable output capability. Read up on the controls in the manual. The Prius has a "desired" temperature control. So, you can set the temperature up to say 80 F. Which will run the compressor and ventilation fans at a much lower speed/power level, but keep things comfortable in the car. When you first start up the car, the AC and fans will run fast, but as the car cools down, the AC and fans will slow up automatically.
    If you run the car a bit (take another route) before you come into a stop/go situation that will be helpful. Because the car will get a chance to put energy in the battery with the engine running at a more efficient power level. Low power levels are inefficient for gasoline engines. The Prius has a better engine in this regard, but running down the road, running the AC, and charging the battery is going to be way more efficient than stopped in traffic with a low battery, and running the AC. Stopped in traffic the AC condensor fan may need to run. Moving down the road, the windflow into the front of the car will do this for free, too.
    Another thing to do is get a sun shade. Any extra cooling that the car needs to do when you turn it on uses battery, which uses gas. Even here in Illinois, I use one of those custom CA made sun shades to cover the entire front window. They sell them in the store here. And though $30 sounds like allot, it will make a big difference in the startup temps inside the car. And this will pay for itself, besides protecting the expensive electronics in the car. If you can park in the shade, that is even better.
    Finally, I believe the car does some new-battery conditioning at first. Which is going to baby the battery, and you wont get the full performance yet.
  4. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    wait until you've run 4,5 tanks through.
    if you've only put on 50 miles , you don't know what mileage you're getting - maybe the tank was full when you bought it, maybe not. the fuel guage isn't that accurate.
    after a few thousand miles, divide your miles driven by total fuel pumped in and see what you get.
    50 miles in several weeks? did i read that right? your average trip must be real short - not giving the engine time to warm up? try resetting the mileage on the mfd and go for a 50 mile highway trip and see what happens.
  5. bwilson4web
    15,934
    Let's go over a few basics:
    • What is your oil level relative to the "F" mark?
    • What are your tire pressures?
    • Does your gear selector show "D" or "B"? (A family member problem.)
    • Can you get a wheel alignment check and bring results here?
    I don't like to address driving style until after making sure the vehicle is truly healthy. You may find this hard to believe by my Prius was handed over by a Toyota dealer with the oil above the "F" mark; tire pressures of 32 psi; one family member who moves the selector all the way into "B" and skips "D"; and poor wheel alignment.
    After making sure the car is in a good state of repair, we can address modest driving practices:
    • Drive 25 mph for first mile or so to keep fuel consumption down and warm up the engine, oils and tires.
    • Normal driving in the speed ranges of 0-38, 45-65 mph and avoid going through 39-44, a place where it can trigger unnecessary engine operation. I use cruise control to handle the speed so I can concentrate on traffic.
    • Drive last two miles at speed under 38 mph and closer to 30 mph is best to use the stored battery energy that otherwise would be lost after being parked for more than 8-12 hours.
    But don't adopt these practices without having the mechanical parts of the car throughly checked, especially since it is under warranty. You already know a rented Prius can deliver great mileage. You are now the 'maintenance supervisor' and can make sure your car does what it should.
    BTW, what part of California? There are Prius experts across the country and the ones that post here are especially helpful. Perhaps not right away, let the dealer do the right thing, but when your happy with getting a little extra help.
  6. richard schumacher
    7,664
    1,042
    United States
    Definitely go check the tire pressure and oil level ASAP. Tire pressures should be measured cold, so either buy a $10 gauge or go to a service station less than a mile away.
    When you rented the Prius did you use it on the same route you're using yours on now?
    Short trips of less than a few miles are death for MPGs in any car. Running the air conditioner in a Prius is insignificant in comparison.
  7. QuelleFromage
    Thanks all. I will try all the suggestions.
    The thing about the short trips: my commute to work is about nine miles each way, which takes about 45 minutes in traffic (yep, that's right, in LA traffic a five-minute miler can run as fast as your car). This was putting me at about 34-36 mpg. But I started seeing the average drop further when the weekend came around- in which I ran a couple short errands, then was driving on the freeway and able to drive better.
    The tires do look low to me, so I'll run out and get a gauge. My dealer seems to have "forgotten" the owner's manual so I'll get that from him when he comes by to add some goodies on Tuesday. Thanks again :)
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    I live in Florida and run the AC at 69 non stop and my mileage is always at 47 mpg's. AC does not affect this car that much.
    Fill tires to 44/40.
    Your running E10 gas which will hose you for 3-5 mpg's anyway.
    Run only 87 octane. Cheap stuff. Anything better will give you worse mileage.
    As Ed said: Sometimes a bad daily route stays in the cars memory for quite a while. If I pick around town all day stop & go it will take 2 days of good hypermilling on a highway to change the mpg ratio. Strange little car. Go on a nice long highway drive.
  9. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    What cheese - in addition to the above ideas, since the car is on it's first fuel load, we can not rule out the possibility that the fuel was of low quality.
    No proof of it, and no need to panic, but I would top the tank off. Easy to do and harmless, while awaiting more info on vehicle alignment, possible dragging rear brakes, etc.
  10. drees
    drees Senior Member
    1,782
    247
    Stop & go driving in hot weather with the A/C running (with the A/C in auto, how fast is the fan going?), you'll get poor fuel economy. Don't worry, that's still probably at least double the fuel economy of your last car. So I'm not too surprised to see about 35 mpg. Leave the A/C in auto and set to the highest temperature you feel comfortable at in hot weather.
    44psi front and 42psi rear will help a little bit. From the dealer they're probably inflated around 32psi or so.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    My lips are sealed.
    those who know me know what I'm thinking.
  12. QuelleFromage
    Tires were a little low. I drove a lot this weekend, not in stop-and-go, and am up to about 110 miles. I'm now at 30.8 mpg.
    I got EPA mileage on my last car, so actually this is not all that much better.
    It kind of bums me out that people who are wholly unfamiliar with me, my driving, and my environment could draw conclusions that place this squarely on my head. I am thankful for the helpful suggestions.
  13. bwilson4web
    15,934
    Did you reset the mileage indicator after adding the air and before driving? The reason I ask is if your mileage indicator was at 26-27 MPG, and you now show 30.8 MPG on top of what you had, you'd have been running closer to 33-35 MPG over the 110 miles. This is less bad but still a problem.
    GOOD LUCK!
    ps. For our math buffs:
    x miles @ Y_1 MPG -> (x/Y_1) gallons for x miles
    z miles @ Y_2 MPG -> (z/Y_2) gallons for y miles
    If z = x + 110 miles (the display was not reset,) then we take:
    (z/Y_2) - (x/Y_1) = Z gallons for 110 miles
    110 miles / Z gallons -> MPG for the 110 miles
  14. Scruge
    Scruge New Member
    97
    TX
    Make sure the engine brake isn't on. See PRNDB display on instrument panel.. There shouldn't be a box displayed around the "B". It will really pull mpg down.
    If after 500 miles your average isn't near 40 mpg I'd take into dealer.
  15. QuelleFromage
    No, honestly- I have driven Prii before. It is not in "B".
    Anyway I am now up to 32 mpg and have just reset the whole shebang - thanks Bob, great point.
    I am wondering if the fact that I live on a very long, steep hill could somehow throw the whole thing off?
    I miss my EV1. But it wasn't exactly practical.
  16. davidhol
    davidhol New Member
    27
    Roseville, CA
    Well, I would take it back to the dealer because there may be a fuel leak somewhere. I just picked up our new 2008 Prius last Friday and have just today passed the 100 mile mark and we are showing 42.9 mpg. The 100 miles is all just running around town, probably less than 10 miles of freeway driving and I have beaten a few other cars away from the green light so I'm not trying to baby it.
  17. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Hmm, I bet you have checked everything. If it is new, take it to the dealer and tell them something is way off. Ask them if they could take a look at it, check the computers and what not. However I think it would have lit something up if there were a code going off. It beats me, but I have heard other posts like this before. Sometimes there is what I like to call "a fart in the system." HAHA Well, good luck and don't be discouraged. Whatever the problem is, it should be fixable and you will be so happy afterwards.
  18. davidhol
    davidhol New Member
    27
    Roseville, CA
    Sure, a long steep hill could easily make that difference if you have driven it many times in the short time you've had the car. I would take it out on the highway at 55 and see what you get then. I think it should show over 50 mpg in that driving mode. I'll do that tomorrow and post my result.
  19. richard schumacher
    7,664
    1,042
    United States
    And their pressure now is...?
  20. timwalsh300
    timwalsh300 Member
    131
    16
    Last week I had an interesting experience in my Prius. It was 100 degrees here in Boston and I had to drive to the train station to pick up someone coming to visit. For those who don't know, driving to South Station requires going right through the heart of the downtown area.
    My lifetime average so far (after 2,300 miles) is about 55 mpg. On the highways I get ~60 mpg and on short trips through the city I get ~50 mpg (25 mpg for the first 5 minutes, and then 50-100 mpg for every subsequent 5 minute block).
    On this particular trip I ran the A/C for the first time, set to 83 degrees, and it was some of the worst stop and go traffic I've ever experienced. It took me 40 minutes to drive 3 miles and I never drove continuously for more than 30 seconds. As a result I averaged 25-30 mpg for the whole 40 minutes.
    From what you describe, going 9 miles, uphill, through very bad traffic, with the A/C running, my guess is that there is nothing wrong with you or the car. It's just the environment. If I had to make that trip everyday I would absolutely not be doing it in a car. Find another route. Or take a bicycle.
    I simply do not believe that your old car got its exact EPA mileage when the Prius is performing this badly. Think about all the time when other cars are just idling and you are not.
    Tim
