using other-than-Ipod MP3 players?
Discussion in 'Gen 2 Prius Audio and Electronics' started by gsmolin, Apr 13, 2008.
  1. gsmolin
    gsmolin New Member
    silver spring, md
    hey all, dumb question here: is there any way to play a non-Ipod MP3 player in a Prius? I have a 2004 model and it has the Ipod jack, but I couldn't find an adapter online or info on one on the forums here.
    thanks!
  2. davidtm
    davidtm Member
    180
    TJ'ville
    The quick answer is connecting the headphone output on the player to the Aux in for the Prius (located in the center console). Not sure if there are adapters as you describe.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    First things first; welcome to PriusChat. It's always comforting to see
    another "Old Line State"-er come on board.
    Standard disclaimer; as I've got a '08, I haven't followed the threads on
    aux-in issues for the early models too closely.
    That said, if you have an aux-in it takes a headphone mini plug. You can get
    a 12 in. cable with male mini plugs on both ends at Radio Shack for a couple
    of bucks. You'd plug it into the earphone jack on any MP3 player.
    But the real question is; do you even have a aux-in jack? Later models,
    '06-'08 have a jack and 12V plug in the center console. As I understand it the
    2004 doesn't. That means you'd need some after market equipment; $$$
    While you're waiting for more input, you can use the search function at the
    top right of the page to good advantage.
    To get you started, this recent thread sounds similar to what you've asked:
    [http://priuschat.com/forums/audio-electronics/42977-stupid-question-ipod-only.html?highlight=ipod
    Good luck
  4. rpiereck
    rpiereck Regenerator
    289
  5. neon tetra
    neon tetra Member
    309
    The AUX-IN is def. one of the things that sold me on the car.
    IMO every car in the last decade or so should have had one.
    As for a non-ipod mp3 player, I highly recommend the iAudio series from Cowon. Far better features than ipod & much better value too.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Make sure to adjust the volume on the MP3 player to get good playback on the Prius. Often you need to crank the MP3 volume up a bit.
    Tom
  7. gsmolin
    gsmolin New Member
    silver spring, md
    thanks everyone for the info. i'll check to see if i have the aux-in jack (crossing my fingers that i do!), but if not, maybe i'll just go the cheaper but less convenient route of burning my MP3's onto a CD...
    thanks again!
  8. aaf709
    3,862
    2022 Prius Prime
    The OP said that they have a 2004. A 2004 does NOT have the AUX input; that started in 2006. To the OP; was this Prius bought new or used? You mentioned that it has an iPod jack so it might have a VAIS or DICE installed. If so, they have an AUX input.
  9. gsmolin
    gsmolin New Member
    silver spring, md
    yep, just checked and no "aux" input on the console, etc.
    i bought it used about a year ago; i guess the only way to tell if it has a DICE unit is to take apart the console/radio (i saw the DICE unit installation instructions on the DICE website and it looks pretty straightforward) and see if there's a DICE unit hidden in the dashboard?
    i assume that if there is, its just a matter of replacing the Ipod cable that's currently hooked up to the DICE unit w/ one of the cables from radio shack that others have shown in this post?
  10. aaf709
    3,862
    2022 Prius Prime
    You don't need to disconnect the iPod cable. Just follow it to the box. On both the DICE and VAIS there's a separate connector for AUX. I know that the DICE would use the same cable as discussed above.
    After that you make a change (on the MFD) to toggle between the AUX and the iPod. On the DICE, if it's in CD2 mode (probably) you press CD "5" and press either the up or down button on your steering wheel. Once that's done, pressing CD "1" will allow you to adjust the volume on the DICE.
    If it's a VAIS, then someone who owns one can help you along those same lines.
  11. gsmolin
    gsmolin New Member
    silver spring, md
    so, mixed news: i took apart part of the dash and found that there's a Valor ILink hooked up to the MFD.
    Bad news (maybe?): looking on PC, it seems most people w/ an ILink are disappointed.
    Anyone out there know if its possible to hook up a non-Ipod MP3 player to the ILink? There's zero help on the valor website. Looking at the unit, there's the port for the Ipod cable and three other ports: "EXT. IR", "SPDIF" (which currently has nothing plugged into it), and "AV/OUT".
    thanks!
  12. rpg51
    rpg51 Member
    200
    Vermont
    If you use a mini plug into the aux jack in the center console, can you run the cable out of the box with the top closed and have enough cable to use the mp3 player effectively?
