Valve Stem Caps w/ Nitrogen Label
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bxzcd, Mar 5, 2011.
  1. bxzcd
    bxzcd Junior Member
    22
    Earth
    After having my Prius for just a week, one of my pretty little blue valve stem caps labeled "N2" is missing on a tire. I just found a pack of 100 on the interwebs for $13.00, so I should be set on N2 valve stem caps for the rest of my life. I ordered them tonight from a small company online, so if they ever show up, I'll let you know (I'll let you know where I got them from if they show up, and if the board will allow it). I don't know if anyone on here actually cares about those little things, but I like to keep mine matching. I'm weird like that.
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    That whole nitrogen thing is a bunch of bunk. My dealer put little green rings around the valve stem, and then screwed the regular old black caps on. Only problem was that they only inflated the tires to 28 PSI. I immediately upped them the 42/40, and couldn't care less about nitrogen. If it goes away or leaks or gets contaminated with regular old air I don't care. I check my tires weekly and can't be bothered with some hokey nitrogen thing.
    REV
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If the N2 fan claims are true, then the oxygen will leak out of your tires and leave you with just N2 in your tires with no effort or $ on your part.:pound:
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have always used 78% nitrogen in my tires with good results, and it's fairly inexpensive.
    roadcykler likes this.
  5. bxzcd
    bxzcd Junior Member
    22
    Earth
    I don't have any expert knowledge on the whole N2 tire inflation issue, but I was under the impression that using N2 offers more consistency in tire pressure through temperature swings. I live in Texas, so right now the mornings are about 40-50F and the afternoons get up to 80.
  6. tumbleweed
    4,067
    692
    Eastern Oregon
    Air in tires usually expands about 1psi per 10 degrees F. N2 a little less but not enough to make any difference. Check your tires cold and let them go up when they get warm, that's what they are designed to do.
    My opinion, N2 makes sense in aircraft tires and race car tires but offers no real advantages for street tires. If you get it free, such as at Costco, fine; if they want you to pay extra for it I would say no thanks.
  7. revhigh
    986
    141
    I check my tires so religiously that it just doesn't matter. I easily check my tires at least once a week, have done that since I started driving 40 years or so ago. It makes a huge difference in handling and mileage.
    If it doesn't make a difference in handling or mileage, then as far as I'm concerned it's worthless. If you're the kind of person that gets his tires checked by the mechanic at oil change time only, then maybe N2 is at a slight advantage over just plain air.
    Not only that, since my brand new Prius came with 28 pounds all around, I'm pretty sure that the dealer wouldn't put my requested 42/40 in the tires as I did.
    I have a compressor in my garage ... N2 is far away at the dealership ... no thanks.
    REV
  8. revhigh
    986
    141
    When you say 'oxygen', I'm guessing you're talking about regular old air, which is only about 20% oxygen, almost all the rest is nitrogen totally for free .... about 78% worth .... all at no charge ... as tumbleweed mentioned ... good one TW ! :D
    REV
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That's the beauty of the N2 mythology. If it's correct, that 20% O2 in the air soon leaks out and leaves you with only N2 so no need to buy N2.
    If the N2 mythology isn't true, then there is also no reason to buy N2 for your ties.:D
  10. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Me too. If O2 and other air gasses diffuse out faster than N2, then I figure my tires act as N2 concentrators. :rolleyes:
  11. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    I considered putting helium in my tires, but was afraid the damn thing would flip over and float away.
  12. bxzcd
    bxzcd Junior Member
    22
    Earth
    This sounds like Monster HDMI cables to me.
  13. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Has anyone ever watched them do a nitrogen fill? Surely just attaching a nitrogen hose to the filler after mounting the tire leaves some "bad" regular air inside.
    Without using a tire/wheel sized vacuum chamber to remove all the "bad" air, how could you ever end up with only nitrogen in the tire? After all on a mounted tire there's only one hole to put in the nitrogen and nowhere for all the "bad" air to escape. If you tried to vacuum all the air out in the open prior to filling, the tire will collapse and dismount itself. If a tire place could answer these questions, I might even believe that the tires were indeed filled with nitrogen. Otherwise I call a capital BS on this scam.
  14. tumbleweed
    4,067
    692
    Eastern Oregon
    Good analogy.
  15. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Other irony...
    If O2 can diffuse through the tire, and you really get all the O2 out during a N2 fill, then some O2 from the air will diffuse back in...and equilibrate at about 3 psi partial pressure inside.
    Nitrogen is a marketing scam. It does not affect T/P variation.
  16. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    I put sulfur hexafluoride in my tires. The traction I get is absolutely incredible. I can pull 3 g's on a standard test track.
    :D
    :D
    :D
  17. tumbleweed
    4,067
    692
    Eastern Oregon
    SF6, I think that's the stuff that replaced oil used to suppress arcs in HV circuit breakers.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The extra un-sprung weight ruins the ride though.:D
  19. Mendel Leisk
    41,824
    We got tires through Costco, on a previous car. Before going in I removed and pocketed the (black) valve caps. So:
    They filled the tires to the pressure posted on the driver's door placard, and put on green valve caps. I payed, drove a couple of kilometers down the road to Chevron (free air), raised the pressures to 42psi with regular air, pocketed the green caps and put the old black caps back on.
  20. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Me too, although I custom blend it with 21% oxygen, argon, and traces of other gases. Rather expensive and time consuming, though.:p
