  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Thx (y)
  2. wotcher
    wotcher Member
    403
    97
    16
    LA
    i noticed that you took off your badges. Have you considered wrapping white portion of the hatch black? i wonder how it will look with the sb valenti and the black hatch.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  4. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    I had it wrapped matte black before, and I didn't like the look of it, I'm putting on my badges back soon, just adding some glossifier on top of the plastidip :)
  5. SCRWGas5
    SCRWGas5 New Member
    156
    Charlotte, North Carolina
    Today I got some more LED bulbs. Two white bright ones for reverse which looks great. Got two amber ones for the rear sigal lights. However I haven't gotten my relay thingie yet for the hyper flashing. My concern is I wonder if the bulbs aren't working. I tried plugging them both in one side, both poles tried. When I hit the flasher on that side I get the hyper flashing front light and nada on the new bulb. Just off. I swapped the poles, tried the other bulb. Still nada. Does the bulb need the relay in order to work at all? Or do I have two DOA bulbs?? Also of note, when I put on the hazard lights, the three working original bulbs blink at correct speed. Just isn't what I expected. Should I wait and try again after the relay comes or should I assume I got two duds?
  6. Larsenvega
    Larsenvega Junior Member
    36
    16
    Tucson, AZ
    Put one of the questioned blinker LED's into the reverse light socket to test it. Even though they're different colors, they are both 7440's, so it'll work as a quick test of functionality.
    SCRWGas5 likes this.
  7. SCRWGas5
    SCRWGas5 New Member
    156
    Thank you dude. lol. Good thinking. I did that and sure enough it's glowing bright amber on reverse. Soooo....hmmmm.....hopefully the LED will work fine in the signal socket once the relay goes in? Cause Fedex just delivered the relay 5 mins ago.
  8. somebody7
    somebody7 Member
    147
    36
    Austin, TX
    Are you going to get the holes filled in or just leaving them like that? I removed all my badges, but I dont like the big empty holes. I checked with one body shop, but they were going to just going to bondo it. I've been reading that getting it welded is better so I asked about it, but he didnt have any welders, they preferred to bondo it so I disregarded their quote. Still looking for someone else that can weld it, I dont mind paying for it, but I want it to look like new and I prefer to get something thats permanent, not something I will have to worry about in a year or two (bondo).
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The LED bulbs should still work without the LED flasher relay.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The fenders are getting welded but the rear hatch is plastic so it can't be welded.
  11. SCRWGas5
    SCRWGas5 New Member
    156
    Any suggestion as to why they aren't working in the signal slot then? I swapped back in the OEM bulb and it's working fine. And the LED is working fine in the reverse light socket. Confused!
  12. somebody7
    somebody7 Member
    147
    36
    Austin, TX
    Yea, thats one thing he told me. They wouldn't have any choice on the lid deck since it was plastic. Im fine with that since there really isnt any work around for that, but not for the fenders that are metal.
    I guess I need to keep getting quotes on body shops and wait for one that will weld them. thanks
  13. somebody7
    somebody7 Member
    147
    36
    Austin, TX
    btw, does anyone know how to get that deck lid off? I dont see any screws on the inside of the hatch on where it can be removed or take apart.
  14. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I picked up a used JDM steering wheel and installed it in my Prius today!
    Sike! Just kidding. I picked it up for Sean though. ;)
    sfv41901, ucsmfu and wotcher like this.
  15. ucsmfu
    1,498
    420
    canada
    haha, it's one of my favourite mods :p
    sfv41901 and Steve Type-4 like this.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    It could have been something as simple as the metal tabs on the LED bulb wasn't making contact inside the socket. I would move the thin metal wires on the bulbs & Try it again
  17. eco-icon
    eco-icon Junior Member
    137
    I got a nexus too lol
    Nexus 7 ? 2
  18. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    Didn't know the fender badge had pins! I thought they were just stick-on badges :eek:
  19. wotcher
    wotcher Member
    403
    97
    16
    LA
    i finally got my trd springs on. they had been sitting in my garage since may. :eek: i planned to do it myself. but the more that i researched, the more it made sense to have someone else install them. the guy even warned against the loaner spring compressor from autozone. i remember taking over 6hrs to install the tanabe stb.
  20. ucsmfu
    1,498
    420
    canada
    how do you find it ?
    It's been almost a week for me, and I'm loving it :)
