What grade of gas is best?
Discussion in 'Gen 3 Prius Fuel Economy' started by passion222, Sep 30, 2012.
  1. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    100, 200k before seals go using E10 - no problem there.E30 has seals lasting 30 - 50k at best,then new seals are in order, unless one doesn't care about leaks, degraded engine performance.
    DBCassidy
  2. WE0H
    WE0H Senior Member
    3,247
    528
    Really? Degraded engine performance? How? Does that E stuff leave more carbon deposits or clog up intake valves?
    Mike
  3. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The Prius actually works the opposite to what you have described to provide high-efficiency.
    The throttle is not used very much to control output power instead the engine RPM is varied. The valve timing will be used to adjust the charge allowed to enter the cylinder during the intake stroke.
    At high power outputs the inlet valve is closed early to give maximum charge in the cylinder, the physical combustion chamber volume means that the cylinder cannot be filled more than ~70% full giving the 10:1 compression ratio and 13:1 expansion ratio.
    At low output powers the inlet valve is closed later to allow some of the inlet charge to be expelled into the inlet manifold. The throttle remains fairly open for both scenarios so the inlet manifold pressure does not drop to the levels seen on a conventional engine - this minimizes pumping loss.
    The Prius does not operate the engine at high RPM low throttle setting under normal conditions.
    kevin
    a priori likes this.
  4. dbcassidy
    1,581
    290
    CAREFULLY, reread post.
    DBCassidy
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    A leaky seal would drop your MPG for sure. ;)
    dbcassidy and WE0H like this.
  6. terpsmandan
    terpsmandan Member
    144
    13-1 is the compression ratio. The VVT system adjusts the intake and exhaust timing optimize the overlap at various engine speeds. The ignition system has a built in knock sensor to retard the spark if the octane (compressibility) is insufficient. One good question, Toyota says 87 or higher. Has anyone tried running higher octane and seen an increase in economy? Can the ignition system provide more advance?
  7. WE0H
    WE0H Senior Member
    3,247
    528
    Some swear by 89 octane while some run the lowest cost gas they can put in there :) Some even run real high octane stuff ;) I never run low octane gas in any of my vehicles.
    Mike
    SGH-I717
  8. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Bob Wilson did tests and got a minor power increase with Premium going uphill, but no MPG gain.
    13 to 1 is the expansion ratio, and so is the mechanical compression ratio, but that is not the useful ratio.
    Listening to this guy, recall that the Prius intake has a minimum closing degree of 72, and can close at 105 degrees maximum.
