What to salvage?
Discussion in 'Gen 2 Prius Main Forum' started by KitsuneVoss, Jan 3, 2026.
  1. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Okay, I have the car off the ground but seem to have run out of PB Blaster. Going to get some tomorrow,
    What I did today was
    1. Removed the coils
    2. Removed the spark plugs - They were only a couple of months old when the engine blew up
    3. Removed fuel injectors - Only a couple o9f months old when the engine blew up
    4. Removed both headlight assemblies
    5. Removed the inverter coolant pump
    Tried to removed the inverter but the security screw stripped out.
    Going to use a grinder tomorrow or Thursday. I don't think I need it.
  2. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Got the catalytic converter and resonator removed. I need to get new gaskets I think?
  3. PrimalPrius
    PrimalPrius Junior Member
    72
    America
    I probably would use new ones if/when installing it into a car I own. But... if the old gaskets look really good and I were just storing the part for now, I might secure the gaskets to the assembly in case I sell it to someone, the buyer might want them...
  4. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Only issue has been trying to find what are the right seals?
  5. PrimalPrius
    72
    America
    Oh, I misunderstood. I thought you were wondering weather of not to store used gaskets that look good.
    (I personally would not buy anything unless the part was stated to soon go into a vehicle I own).
    In my case I would salvage rims for winter tires or pothole triage. (Unless necessary to get rid of the vehicle).
    And hang front and rear bumper cover from the garage ceiling if they are in good shape.
    But, with that kind of thinking one is soon storing doors, abs modules, etc...
    #25 PrimalPrius, Feb 12, 2026
  6. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    It would be nice if I knew the right seals for what I do need to use it. I actually think I will want to use it.
    Pulled the whole thing, the cat and resonator, off a few weeks ago but has been pretty bad weather since.
  7. ebikeman
    ebikeman Member
    116
    Northwest
    Yes you could. The problem those years is the water-pump was electric. It slowed down as it got older and since you don't have a temp gauge, people never knew it was hot with a slow running water-pump.
    Replace the head gasket and the water-pump, WP with one from Toyota and your set to go.
    ebm.
  8. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    When I looked at the car, it had the triangle of death. I am not buying a car with that.
  9. PrimalPrius
    72
    America
    On my Gen 2 just a low 12V battery can cause the red triangle. I assume that Gen 3 is the same/similar, but I don't know.
    Personally I would never even consider looking at a Prius without a scanner that can read multiple modules including HV battery block/cell voltages. Or any other car.
    (I only had a basic OBD2 reader when I bought my Gen 2, but I would never shop for a car without a better scanner again).
  10. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    They tried to tell me it was nothing but "Check Hybrid System" is not nothing.
    I ended up with another 2nd Gen.
  11. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Weather has been bad so not had a good chance to work on removing parts until just recently.
    Had snow multiple times in the last month, which turns the driveway into mud, even if I could deal with the cold.
    I did look at the lower engine mount on the 2006 and it moves around a lot, making me think that it is not worth saving.
    I could not get the front O2 sensor off due to whatever shield is around it and that the exhaust manifold is loose.
    Saturday and Sunday did get a lot done though on the 2006. Used an electric ratchet and electric screwdriver, which helped immensely.
    Removed both the aux battery and hybrid battery Saturday although did not clear room in the shed for the hybrid battery until Sunday. Sunday, I also removed the upper glove box, the one on the 2005 had a cracked hinge, the interior trim (which was less than a year old), and the multi-function display.
    Still need to get the inverter and abs module off and need to figure out what I can do about rims. It has alloy rims and like to save them if I can. I can take up to two of them by replacing them with spares. Any suggestions with respect to rims? The 2009 has standard rims so one of my thoughts is to transfer them.
