Whichs pips last the longest.
Discussion in 'Gen 2 Prius Fuel Economy' started by burritos, Apr 24, 2008.
  1. burritos
    burritos Senior Member
    4,946
    252
    Is it the same for every prius. For me pip number one and the third to the last seem to last a lot longer than the other pips. I don't know how long the last pip lasts, but I fill up usually before the blinking occurs.
  2. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    Well since it's a bladder tank, the change in temperature would cause it to expand or contract. and doing so while driving would make one pip seem like its lasting longer than another. (that's what I would think at least)
    But I would say that it seems like the first pip lasts the longest. I usually see it go when I am around 100 miles
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    First Pip (full tank) about 75 - 85 miles
    All of the rest of rest excluding the last one about 45 - 50 miles each.
    Last one (before it blinks) 20 - 25 miles
    (this is just my average your guess guage may vary)
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    First pip definitely lasts the longest. Seemingly twice as long as any of the middle eight pips.
  5. SpartanScott
    SpartanScott Michigan Member
    60
    Howell, Michigan
    I'll post my observations also:
    First pip (full tank)= 50-150 miles
    Other 9 pips = 40-45 miles
    The miles you get on 10/10 pips depends on temperature, Hotter it is the more miles you will get. Overfilling the gas tank also adds more miles to this.
  6. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I'm at exactly 150 miles and still on the first pip. As others have said the first pip (and really any pip) largely has to do with the temperature. It's been in the mid-eighties in Phoenix so my tank was pretty elastic when I filled up.
  7. charansr
    charansr Member
    107
    Concord CA
    My first lasts the longest (50-60 Miles)
    Rest @ ~40Miles
  8. charansr
    charansr Member
    107
    Concord CA
    Rest @ ~40Miles
  9. Dipena
    Dipena Senior Member
    1,567
    68
    Massachusetts
    I hope this isn't a dense question, but does this mean it gets better mileage when the tank is fuller?
    I'm a newbie and I'm still figuring this stuff out.
  10. Boo
    5,051
    488
    97
    Flushing, NY
    No. The pip measures are just a rough gauge.
    My guess is that the first pip (counting right to left) is akin to the full mark on an analog needle gauge. Takes a longer time for the needle to get to the 7/8 full mark because when the tank was full the needle was past the full mark to begin with.
  11. metal_chair
    metal_chair Nashville Prii Unite!
    65
    Nashville
    mabe first pip also includes whats in the fill tube?
  12. morpheusx
    1,555
    81
    Akron, OH
    it means that when you fill all the way up you are beyond the measurable capacity of the actual guage. All it knows is that you have more gas then the highest measuring point. Sort of like how refilling a water bottle to the fullest point is higher then the measured 16 ounces that was in it prior.
  13. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Personally, I really don't care which pip last the longest. All I want to know is how good or bad my mpg is after a tank full. ;)
    In terms of 'pip', I think the first pip last the longest in my Prius.
  14. hill
    8,583
    It's the one you never looked at:
    A watched pip never evaporates
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    I'm on a record high for me first PIP at 220 miles. This was after my first air in the tank gas came a gushin' out episode. I filled it right to the top of the neck by mistake after months of hanging the pump up on first click. Filling to top of the neck is very bad. I was a little worried that the PIP was not moving at 200 miles but from 220 to 280 it has dropped to 3 PIPs gone.Usually the first PIP has been 60 to 90 miles. Its wacky.
  16. patsparks
    10,664
    567
    Adelaide South Australia
    The bar on the left end stays on the longest because it is on all the time from a full tank right to the last and then when or if it flashes all the others have already extinguished so it is obvious the left end bar lasts the longest.:whoo:
  17. patsparks
    10,664
    567
    If you think the first bar of the gauge lasts longest is because there is fuel in the filler neck have a look under the left rear wheel arch and see that the filler neck isn't a big thick pipe but is only about 1 inch inside diameter so it wouldn't hold a lot of fuel. There is a breather pipe which lets the vapor out and that is smaller again.
