Widest single dimension for hatch opening?
Discussion in 'Gen 5 Prius Technical Discussion' started by scotched, Jul 1, 2026.
  1. scotched
    scotched Member
    81
    112
    Encino, CA
    2023 Prius
    I'm looking at transporting a rigid office chair mat which is basically a thin sheet of tempered glass.
    Length is doable and thickness is less than 0.5". Just wondering what the maximum widest dimension would be at the hatch opening. I'm assuming it would need to be inserted at some odd angle.
    Has anyone else tested the limit of their hatch with a similar object?
  2. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    I believe you don't want the widest hatch opening dimension, but the most narrow width of the floor with the seats down.
    Transporting a piece of glass wider than that at an angle supported only by the edges sounds like the beginning of a story that doesn't end well.
  3. scotched
    scotched Member
    81
    112
    Encino, CA
    2023 Prius
    @Winston Smith
    I had assumed the hatch opening was more narrow than the space of the seats folded down.
    This piece of glass is designed to have a heavy office chair + full size person sitting/rolling around on it all day. If it cannot survive a car ride with no load I'd be surprised.
  4. BiomedO1
    BiomedO1 Senior Member
    4,633
    2,433
    Left Coast
    That calculus holds true when you have a good flat supporting structure underneath it. If you need to transport it on an edge, rather than laying it flat on your cargo area - it can crack or break without proper packing around it.
    Winston Smith likes this.
  5. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    At some points, yes, but the space will narrow somewhat between the wheel wells.
    Those are neat and can be very durable on a floor where they can't flex much. Bend it between two distant points and it will flex right up to the point it doesn't.
    This may illustrate the importance of a friend with a pick-up or van.
  6. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Load the glass into the car. Then, roll up a bunch of blankets to fill the space under the glass. Enough to keep it from touching the car's interior directly. That large support area will relieve stresses.
    RobotBastard likes this.
  7. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    What a bunch of bs responses!
    The opening is 34 1/2” wide.
    There’s 37” between the wheel wells and a flat area about 68” long with the driver seat in the position I like. This is for my 2024 Prime.
    And, tempered glass will not break easily!
    scotched likes this.
  8. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Tempered glass can shatter very easily if it's hit on its edge.
    If the OP has to transport the glass at an angle, I'd pay more attention to the edges and less about supporting the middle. Make sure the entire edge that's on the floor is cushioned so there are no points of hard contact. And don't let the upper edge be supported at only a single small point. Finally, be careful when sliding it in and out so that an edge doesn't get bumped sharply. Basically treat it like the glass trucks do: cushioned on the load bearing edges and let the rest float free.
  9. LRO
    LRO Member
    97
    98
    United States
    2024 Prius Prime
    XSE Premium
    As @mva states ... you've got an opening width of 34-1/2" ....
    But angles help and the math says you can slide in a 48" wide object through an opening 34-1/2" wide and tall if you can tilt that item 45 degrees but that's not possible where all the nuances of the three-dimensional Prius hatch are involved. For this particular circumstance, I'd say your vertical clearance through the hatch to be in the vicinity of 19" with a workable width of 31". Those dimensions would permit angling in a chair mat up to 36" wide. Mock ups with cardboard could give you proof.
    FWIW ...standard sizes and approximate weights of tempered glass chair mats.
    36×36 30- 59 lbs
    36×46 38- 75 lbs
    40×46 42- 83 lbs
    42×48 46- 91 lbs
    46×60 63-125 lbs
    48×60 66-130 lbs
    48×72 79-156 lbs
  10. scotched
    scotched Member
    81
    112
    Encino, CA
    2023 Prius
    @mva
    Lol, Thanks for the actual reply. Priuschat is ... Priuschat.
    @LRO
    I took some measurements yesterday and came to a similar conclusion. 36" x 48"L is what would comfortably fit.
