97 MPG commute ... aiming for 100!
Discussion in 'Gen 2 Prius Fuel Economy' started by JimboK, Jun 11, 2009.
  1. Midpack
    Midpack Member
    461
    43
    Chicagoland
    I don't get these high numbers. No matter how hard I try I can't get anywhere near that...
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Hi Ron,
    My biggest surprise in reading data from Scangauge was the average speed, but then I realized it includes driving in heavy traffic and stopping for stop light / signs. Could be sitting at a red light for 2 minutes - you're not moving thus your average speed for the total trip is going down. More red lights ... and heavy traffic ... you get the message :)
    Gabe
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    100 mpg!
    I did it! At least according to CAN-View. ScanGauge wasn't far off.
  4. KV55
    KV55 Member
    126
    43
    Northamptonshire, UK
    Excel
    Well done Jim, I'm very impressed. Did you make any big changes or is this the result of just fine tuning? I notice the ICE use dropped from 29 to 25% and it took about 10% longer, does that sum it up?
  5. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Well, not even any fine-tuning. Temperature was a little warmer and I had some luck with lighter traffic. There are some two-lane segments, one with 45 MPH PSL and others with 35, on which I usually have traffic behind me, but today had none. So I could go considerably slower there.
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Wow! Waiting for the detailed write up...
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    What is the AH: 3.83?
    Is it the average amp drawn from the HV battery?
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Great job Jim!
    That only functions for Plug-In Prius. It lets us know how many Ah we took out of the battery. It comes in handy to find out how much longer we can travel in EV mode.
  9. 2009Prius
    2,705
    512
    63
    So all this is with a plug-in?
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    No. Jim is doing it all on a stock Prius. The CAN-View is used for plug-in's but any prius can use it. Its kind of like a ScanGauge but more useful.
  11. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Well, close to stock. ;)
    Jay is correct of course, that I don't have a PHEV. I do have a block heater and an EV button.
  12. 2009Prius
    2,705
    512
    63
    Thanks! I didn't know CANVIEW could be installed in a non-plug-in. Now is there a formula to convert the electricity used for the EBH to equivalent gallon of gas? If so what would be the equivalent MPG for a Prius without EBH? Thanks!
  13. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Oh I see. Since the HV battery pack is rated at 6.5 Ah, it is at about 60% SOC. Prius use the HV pack between 40% to 80% state of charge and aim to stay at 60%.
  14. 2009Prius
    2,705
    512
    63
    Somewhere there was a brief mentioning of a Japanese driver who keeps the charge level low to get higher charging efficiency. Any idea/data?
  15. JimboK
    2,817
    190
    49
    Chesterfield, VA
    No data, just the widely accepted belief that it's best to use the ICE and the resulting kinetic energy directly for propulsion rather than suffer conversion losses by moving energy into and out of the battery.
    There will be specific circumstances that probably justify SOC down more -- e.g., before descending a long downhill where significant regeneration will occur.
  16. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    JimboK,
    Congrats on the ++ MPGs. Guys like you are a constant encouragement
    to the rest of us Gen II owners.
    I routinely get 55ish MPGs on my daily summer commute. I recognize
    and accept that the nature of my mostly urban driving in limiting. On
    rare days when traffic is light and I hit the traffic lights just right I'll get
    low 60s. With guys like you way out in front, everyday is a new challenge.
    With the HSD, there are many little operating details that at first blush
    appear to be counterintuitive, eg, not using the HV battery for primary
    propulsion. But if you look closely, they are based on sound principles,
    in this case MPG reduction due multiple power conversion losses.
    I think I need a little education on why keeping a low HV battery
    charge level -- as seen on the SOC screen -- would be a good idea.
    From my experience this idea really is counterintuitive. I'm usually
    trying to keep a high SOC and get no HV charging at all.
    Some background: I have a ScanGauge, so I can read RPMs, etc. (But
    in fact, I'm kind of lazy and I don't do a lot of gauge switching when
    underway.) I have noticed that when I'm on the highway, cruising
    steadily on Cruise Control, the HSD likes to keep the SOC up around
    high 6 blue bars -- 65%+ on SG -- and even into the first green bar --
    67.5+ SOC. I take these SOC conditions to be indicative of what the
    HSD considers most desirable/most efficient.
    So when I drive, I look for opportunities within the accepted
    algorithms to get and keep high SOC. Those algorithms would include:
    * minimize regen -- yes, some does happen down hills, etc.
    * maximize no arrows glide
    * accelerate in the 1600-240 RPM band
    * whenever possible drive at speeds/RPMs that result in no energy
    flows into or out of the HV battery.
    I have noticed that at lowish SOC conditions, 50% as an example,
    RPMs are higher, as the HSD "bleeds" off power through the power
    split device to MG1 to raise the SOC. At 65% SOC under the same
    conditions, -- including speed, topography, etc. -- RPMs are lower --
    no power is directed through MG1, and I'm assuming MPGs are higher.
    My question then is, if my understanding is correct, why would trying
    to keep SOC low be a good idea?
    Like it or not the HSD is going to bleed of power at every opportunity
    to charge the HV battery to it's preferred ~65% level. Yes? No?
  17. 2009Prius
    2,705
    512
    63
  18. JimboK
    2,817
    190
    49
    Chesterfield, VA
    Thanks for digging that up. I had seen that and was aware of the "world record", but I had forgotten any details of that thread.
    I would bet she used the conventional method of gliding -- i.e., feathering the pedal enough for all arrows to disappear on the Energy screen. Even though the screen suggests no current flow, there actually is some out of the battery, up to about 8 amps depending on speed. For this I do have data, which suggest that, in my test conditions using that method, SOC maintains a state of equilibrium of sorts at around 55-56%, or 4-5 bars. I know from other threads (sorry, I can't find any to link at the moment) the Japanese hypermilers use a faster acceleration rate than what I tested. With a faster rate the battery has less time to charge during pulses, so it seems plausible that a lower equilibrium level -- i.e., the reported 3-4 bars -- is maintained. It's not clear to me from Yoshi's thread if those low levels are deliberately sought or they are just a byproduct of the chosen acceleration rate.
    As a result of my testing, these days I mainly use neutral to glide, which as you can see from my data results in less current draw out of the battery and higher level of SOC equilibrium. I also accelerate even more gently than the rates I describe in my tests above. I have done some preliminary testing comparing various acceleration rates during pulse and glide. With all due respect to the Japanese hypermilers, the results suggest these gentle rates are at least as efficient as those in higher ranges. I emphasize, however, that this is preliminary testing. The test environment was less than ideal (traffic disrupted my glides on the two-lane rural road I was using), and eventually I'd like to repeat the tests in a different environment.
    So to summarize: I am convinced my results are at least as good if not better when I stay out of the battery. That is, except in low-demand conditions where it's likely inefficient to run the ICE, like extending a glide a short distance or moving between closely spaced red lights. But in those situations I've got plenty of juice for a short run of EV mode, because I've kept SOC high.
  19. Pakman777
    Pakman777 New Member
    103
    Colonial Heights (Fort Lee), VA
    GREAT! Gives the rest of us something to strive for! Good job.
  20. 2009Prius
    2,705
    512
    63
    Thanks for more detailed info! I am also very interested in finding out the best acceleration rate, since "glide" is easy but "pulse" can be hard or soft and there are different opinions out there which one is better. Please keep us posted your findings. Thanks! :)
