How to accelerate?
Discussion in 'Gen 2 Prius Fuel Economy' started by tangmu, Aug 29, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    No, since you drive upside down, mashing the pedal to the floor is actually the preferred method.
    Tom
  2. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Wow, I'm really getting Pummeled here. I understand your experience and excellent results and I'm not taking anything away from that, although, many people out there who are getting 38-50mpg in their priui would love to get 57-60. The method I have used may not be the best or most efficient but it is easy and does not require any additional instrumentation. I have and still own other hybrids and honestly, habits die hard. In my Altima Hybrid as posted at greenhybrid, I have demonstrated best in class efficiency, that should count for something. Anyway, as stated, I will try different methods as soon as this tank expires.
  3. qbee42
    18,058
    3,081
    Northern Michigan
    No intention to pummel. In these forums we often discuss and debate various subtle aspects of Prius operation and technique. Often there is insufficient information, or only subjective results, which makes it impossible to reach a hard conclusion. Occasionally a topic comes up that can be addressed with hard science. Electric operation is one of the topics that can easily be proven to be inefficient for ordinary operation. It doesn't even require physical testing. A simple black box engineering analysis will show that it takes more energy to go through the conversion-charging-discharging-conversion path.
    Once again, I'm not picking on you personally. In the interest of playing nicely, people often acknowledge that other interpretations may exist, or that one person's experience may differ from another. Often this is true, but not always. This is one of the few absolute cases where there is no wiggle room. As an engineer, I like absolute cases. Unfortunately there aren't many of them. :)
    Tom
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I don't think anyone's out to get you, but the method you use/recommend is known to be inefficient. Many people think its good, in part, b/c many of the Prius ads talked about starting in electric only, then many car reviews talked about the fact that you can do that...and indeed you can. And indeed you should in very low speed/creep and crawl traffic. It's a common misimpression and we're just trying to quash the impression...not you.
  5. richardp
    richardp New Member
    New Port Richey, Florida
    Please excuse a dumb question. I bought my '07 Prius less than a week ago and I'm confused about the lingo here. What's 'gliding' and how do I do it efficiently?
    BTW I posted elsewhere that I got 18mpg on my first errand because I left the parking brake on. I believe its possible to get much better mileage now that the brake is off.
  6. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    That brake sounds defective: I really can't move my car with it on.
    I'm a fan of getting up to speed in a hurry than kicking in the cruise. All that stuff about the cruise not being as efficient overlooks the boring work of having to closely monitor the car to squeeze out every last MPG.
    It's been my experience that getting 50MPG is not always going to be possible depending on where you live. Just kicking around Western NY (like Lockport), I got 50+ doing the same stuff I do here, but HERE I get maybe 43MPG. Flatter roads lead to better MPGs.
    As far as 70+MPG, well, like I said, sounds like WORK...
  7. qbee42
    18,058
    3,081
    Northern Michigan
    LOL - yes, the parking brake will hurt your mileage.
    Glide is when you coast with no regenerative braking and no thrust from the engine or motors (or only small amounts of either). The Prius simulates normal engine drag by applying a small amount of regeneration when you take your foot off of the gas. Adding just a small amount of gas will cancel this and produce a glide. It can be seen as a zero arrow condition on the consumption screen.
    Tom
  8. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yeah, in that light we should be talking about Gallons per month/year and nothing else. :D
    If you keep track of miles per period, MPGs can always be calculated as well. But having the numbers for both the miles and the gallons is much more useful because then people who drive a similar number of miles can compare directly with each other. :)
  9. Bob64
    1,540
    93
    Virginia
    How to accelerate?
    By pushing the car up to 10 mph :)
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I wish I had a little handout on how to get the best MPG with a Prius...
    ...there is a silver pine mica that lives in the same town I do, that consistently crawls along at about 5 mph. I'm sure she is TRYING to get good mileage, but all she is doing is p***ing off everyone behind her.
  11. Tinbolas
    Tinbolas New Member
    Costa Rica
    I just bought a new 2009 prius, on my first tank i averaged 54.24 MPG which i feel is excelent, but im also still unsure on how to accelerate, specially when i start with an uphill gradient. I seem to average about 30~MPG when going uphill which i feel i could increase :confused:
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Naw it's totally normal to use much more fuel going uphill. Just remember that even on a modest grade hill you'd be gliding at practically zero fuel usage going the other way. Now if you average the uphill and the downhill fuel consumption at 30 mpg going up and zero fuel usage going down you get a very repectable 60 mpg. :)
    Actually I'm often averaging only 20mpg or so going up hills. Of course it depends on the gradient of the hill though.
  13. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Edit: Whoops, sorry for bringing up old thread...posted to ask a question, turned out I missed the entire second page of discussion, and now can't find the delete button (yikes!).
