How To: Upgrade Head Unit (Kenwood eXcelon DNX6960)
Discussion in 'Gen 2 Prius Audio and Electronics' started by usbseawolf2000, Feb 22, 2010.
  1. Aonarach
    Aonarach New Member
    Bay Area, CA
    For now it's simply terminated with electrical tape. :p When I get in there again I'll terminate it in a better way. I just need it a backup camera right now and after enough research it became clear this wire didn't have to be plugged in at all.
    No new thread just yet. Have to write it all up in word and make it a pdf much like yours and then write even more up for a new thread. The pdf I'd just like to make install info but for the thread I'll give more feedback on what I think of the Pioneer HU etc. Just have to have time to sit down and edit everything with pictures.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
  3. mdsinger2
    mdsinger2 DynamicBrake
    23
    Virginia
    so i got my avic installed! Pioneer AVIC-X930BT, my question to you is, Dont the side pieces to the install kit seem, um, Cheap? it was only like fiddle with them till they sit just right and im not big on that. any tips????
  4. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    I put electric tape on the "anchors". They slide right in tightly.
  5. trigga
    trigga New Member
    17
    SC
    Sweet setup!! Would the same work for a 05 with JBL NO NAV? My 6 disc change is giving me problems and I was thinking of upgrading.
  6. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    If you are not going to reuse the stock JBL amp, everything should be the same. I am using the internal amp from the DNX6960 to power 6 of my Infiniti speakers (a pair of componenets front and 2 normal rear).
    I believe your JBL came with 9 speakers. You can keep the stock speakers and the internal amp from Kenwood should be able to power at least 8 (4 pairs of components).
  7. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Perfect, just the tidbit I was looking for in re-reading this whole thread. Thanks!
    I've put in the single DIN Kenwood KDC-X995. Finally succumbed to HU upgrade temptation. Everything working well so far EXCEPT that I couldn't program my SWI-RC. Must be a bad ground I did with a t-tap into the Metra harness (70-1761). I hate using t-taps, should have known better.
    Same behavior tho - no confirmation/continuation after programming the first button.
    I'll add a separate write up on the X995 install at some point. Haven't had much time to play with it, but so far very impressed with the iPod/iPhone, BT & Pandora treatment.
    - D
  8. 5prius5
    5prius5 Junior Member
    Schaumburg, IL
    This is a great post...thanks usb...
    I am going to install DNX6160 this weekend with backup camera and will follow your directions. One thing I am not doing is installing the steering wheel jack; everything else will be pretty similar to your setup. Wish me luck J
  9. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Good luck!
    It's posts like this that make me happy in knowing that the write ups that PC members do can make a difference by helping others.
  10. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    Awesome. PM me if you are stuck or have questions.
  11. 5prius5
    Schaumburg, IL
    Thanks guys...waiting for my backup camera which is coming from China otherwise got rest of the stuff ready to go...
    @usb thanks for the offer, I am sure I will need your help with the wiring...
  12. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    I just helped a local Prius owner install Infill G4 CarPC double DIN unit.
    Here is the video showing the boot up and the user interface of it.
  13. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Very cool! I may have to switch to a double DIN unit! lol
  14. Stormz
    Stormz Member
    105
    Perth, Australia
    usbseawolf... would love to know more details about how the infill pc went.
    Did you have to buy the yellowtop battery so the pc didn't drain the standard one too much?
    How much was the pc, and what power converter does it use? What are it's features? Did they buy a SWI-JACK to control it from the steering wheel (if they could)?
    Tell me everything :)
  15. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    Andy already installed YellowTop battery since the original battery was going bad. He reported going from high 30s to low 50s just by installing new battery and adding air to the tires.
    They no longer make Infill G4 but it was sold for $2,200 at MP3Car.com, ouch. This place has all the features and information about the unit. Centrafuse supports this unit so you can also google what this unit will be capable of doing with that software.
    The unit runs off 12v DC so there is no need to convert between DC and AC. We tried to use the power from the harness but ran into a problem. Yellow wire is a constant power and Red is a switched power. The unit booted with the Yellow wire but the fan keeps running along with faceplate LED lights remained on.
    We needed to use the Red wire so it only comes on when Prius is turned on. However, it only has 5 voltage and unable to power the unit. I guess factory headunit and my Kenwood runs on 5V? Anyway, we end up tapping the power behind the cig lighter below the passenger drawer. It works great.
    We installed the GPS antenna behind the MFD and the 3.5mm mic extension cable since he didn't have a noise cancellation mic yet. We drilled a hole behind the drawer underneath (with the door where F8L did the stealth install) and put the AV input (3 RCA) and 2 USB cables. We plugged in USB bluetooth dongle to pair his phone.
    Regarding the steering wheel control, it appears a software driver is supposed to enable it as long as it is not over the CAN bus. I don't think Prius audio button controls are over the CAN bus. That wasn't a high priority on the list so we have not work it out yet. He can still use the steering wheel to control the A/C since the harness that came with Scosche TA2103B took care of it.
    Now, for the not so smooth part. I had the battery disconnected before starting the install. When we needed to test and figure out which wire to power the unit, I connected the 12v battery back. While trying with either the Yellow and Red wires, we got careless and did not tape up the unused wire. It got short circuited and blew the fuse. I popped the hood and replaced the 15A fuse with the spare one.
    When we were done and put the MFD back in and tested because we put everything back. MFD was dead and no power even from the clock. The hazard button and ODO button worked. A search on PriusChat lead us to a second fusebox location. It is under the steering wheel near OBDII port. 7.5A ACC (#16?) fuse was blown. We went to AutoZone to get the hard to find low profile fuses and luckily they had them. Unluckily, they only had 5A or 10A and no 7.5A. We decided to get a pack and used the 10A. MFD came back alive.
    If we get more stuffs working, I'll post an update.
  16. Stormz
    Stormz Member
    105
    Perth, Australia
    I was browsing ebay for car pc's, and came across a seller, who I asked some questions regarding car pc's and the Prius. This was his answer:
    "You shouldn't have to worry about the operation of the Prius's hybrid dynamics having an effect on the Car PC. The Car PC will look for a "on" signal from the car and does not actually have anything to do with the car's engine running.
    In explanation, there are 3 basic power connections from the Car to the Car PC: 12V+ (constant, e.g., battery), 12V- (ground) and ignition (12V+, switched).
    The ignition power source, on the car, is what keeps all of the car's electronics "on". This ignition 12V+ will stay on as long as your Car is on, regardless of which engine is in operation (otherwise all of the lights, instrument panels, HVAC controls, etc would cease to function). You would tap into this same switched, 12V+ power to let the Car PC know when you need it to be on and off.
    To answer your related question, no, you won't need a physical switch to turn the PC off; this operation is handled by the ignition wire.
    In regards to your power concerns, the power consumption of a Car PC is fairly minimal. A system like this one consumes less than a premium factory-radio and no changes will need to be made to your car's electrical system. You will, however, need to make good, solid power connections (e.g., don't use the cigarette lighter connector) and make sure you're using a proper wire gauge for the length of wire you need to complete the installation."
    Is that the best Scosche harness to get, for the Prius and car pc's (and maybe most after-market things)?
    So a SWI-JACK/PAC is not an absolute necessity to get the steering wheel controls over to a new unit? That would be great.
    I`m debating whether to leave the JBL stereo where it is if I went the car pc direction, and get a monitor that mounts on the dash.
  17. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    The 12v switched wire (red) wasn't providing 12v even in Ready mode. The constant 12v wire (yellow) did have 12v. That's why we had to tap into cig lighter wire that is switched and also provide 12v.
    I only have experience with Scosche TA2103B. It comes with a harness to keep the AC working by terminating the CAN bus with the resistor. It also come with face plates for double DINs install or a tray for single DIN install.
    SWI-JACK/PAC is for aftermarket brand head units. None of those companies make CarPC. For Infill install instruction, one wire is necessary to connect and software driver take care of the rest. I don't know if the other CarPC wire the same way. The best is to check install dic before you buy.
  18. 5prius5
    Schaumburg, IL
    So I was finally able to install the DNX6160, it went okay...some issues which I will list now and ask for assistance :)
    1: The Backup Camera: I ordered one from eBay which said it will work with 05 Prius, here is the listing , but it did not fit my Prius cut-out. So I did not install that and now going to order this...any other recommendation?
    2: The iPod Kit: I got the Kenwood cable and hooked my iPhone 4 with the unit. In the initial setup when I selected iPod interface it did not play videos but it gave me interface to control music from the unit. However, if I selected Video 2 as an input it played video but it did not give me the iPod interface to control music. I called Kenwood and they said iPhone 4 is not compatible? Any suggestions.
    3: Phone Bluetooth: I paired my phone, Sprint EVO 3D, with the HU and it connected fine. Phonebook, Recent calls and all other sync worked however when I make a call I can’t hear anything but the person on the other side can hear me just fine. I checked all the volume buttons on my phone everything is good, is there a setting on the unit somewhere which I am missing?
    I used F8L YouTube videos to get to the HU and then USB's guide to install it. Great help guys thanks a lot...
  19. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    1) I would check the repair manual to see how the 2005 OEM backup camera looks like.
    2) I also don't get the video, just the audio. I just listened to the audio anyway so I am ok with that. Using Video2, you get the video and audio? You should be able to control it from the steering wheel buttons.
    3) My Kenwood unit has separate volume for Bluetooth. It uses the same knot but the volume is saved at different levels than Garmin for example. When you are making a call (when you should be hearing the dial tone), turn up the volume. BTW, do you hear the dial tone?
  20. 5prius5
    Schaumburg, IL
    Well 2005 did not come with a backup camera so there is no "OEM" solution for it. But the cut-out is at the same spot as 2006 Prius. The 06 OEM Prius camera goes for around $250 so I thought I would just get something aftermarket to take advantage of the option I have in my HU. Not a big deal but good to have. So if someone has already installed one of these I would like to know which exact model they used to make things easier.
    Yeah I do get the video and audio if I select Video2 in the initial setup but then I lose the iPod control, which is cool to have. No, the steering wheel buttons are not working because I have not installed that SWA switch.
    I tried couple of different settings and now I can hear the voice but it’s very very low, so I know it is a setting issue I just can’t seem to find it. During the call when I turn the knob it goes up to 35 but nothing really happens. I think it is not finding the Bluetooth volume somehow....not sure
